Why does my Kindle have lines on the screen?
I can't read any of my books. Instead, there are just vertical lines across my entire screen.
Это хороший вопрос?
Это хороший вопрос?
Unfortunately this indicates the display panel has been damaged and will need to be replaced.
Был ли этот ответ полезен?
While it is very possible that the display panel is damaged, your Kindle may only be affected by interference from more powerful devices, such as a printer or computer. After moving away from these devices, restart your Kindle by holding down the power button for 30 seconds.
If the lines are still there, then it is safe to say the display panel has been damaged as st3v3w described.
This information and more can also be found on the Kindle 7th Generation troubleshooting page.
Best of luck!
Held the power button down and the lines went away. Worked !
Restarting it worked for me. Thank you!
I held the power button down for 30 LONG SECONDS and it worked like a charm! THANKS!!
За последние 24 часов: 3
За последние 7 дней: 18
За последние 30 дней: 88
За всё время: 37,447
