An Android smartphone identifiable by the model number d2004 or d2005, released in March 2014.
13вопросов Показать все
Is it possible to repair the lcd connector on the motherboard E1 D2005
Hi.
I was trying to replace the lcd of an Sony XPERIA E1 and i damaged the lcd connector on the motherboard, i looked around on the internet for a replacement part but i couldn't find the part anywhere. It would help me a lot if someone could help me with this. I've just started practicing micro soldering and i think i would be able to repair it if i just found the part.
Thanks
Это хороший вопрос?
Оценка 1
3 Комментариев
IS there anyone who can help me?
из
You have to find a expert who specializes in those repairs
Also have to buy the part might be better off buying a new phone
из
Thanks for the answer!
из
Добавить комментарий
2 Ответов
Выбранное решение
You're right that sourcing these parts is waaaaaay harder than actually microsoldering. If you're really into microsoldering, you could try to skip the connector. i.e. solder tiny microjumpers from the flex straight to each pin on the pad.
jessa
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
Thanks for the answer! I will try doing that :)
из
well to be honest with you HOW DID YOU DO THIS? omg isn't it hard by the way. Sony xperia e1 isn't that mentioned BECAUSE PEOPLE CANT BE BOTHERED TO BUY 1 I FEEL SO SAD IM SO SORRY I GOT A PROBLEM TOO I AM SO SORRY
Оценка 0
Добавьте свой ответ
Vegard Jakobsen будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 4
За всё время: 1,683
