This all purpose Android tablet was released in May 2013. It features a 7" 800x480 LCD screen, dual-core processing, and supports up to 32GB of additional memory.
13вопросов Показать все
Why do I hear a buzzing noise?
Whenever I use my earphones with this tablet I hear a constant buzzing noise coming out of the right speaker. It is fairly faint but loud enough to be an annoyance. I have tried changing the audio file numerous times but the problem still persists. Thanks in advance for any response.
Это хороший вопрос?
Оценка 1
1 Комментарий:
Try using a more decent earphone.(expensive one).
из
Добавить комментарий
1 ответ
One possibility could be that the device is not the problem here; the headphones you are using could also be at fault. Try using a different pair of headphones to see if the problem still persists.
Be sure to check out the Troubleshooting page for more information.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Antoninus Lamptey будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 134
