ZTE Boost MAX N9520 boasts a 5.7-inch HD IPS Display with 4G LTE and Android 4.1.
59вопросов Показать все
ZTE Boost MAX N9520 will not power o or charge.
ZTE Boost MAX N9520 does not charge or turn on.
Purchased the phone 2 moths ago. o issues or problems until yesterday. The phone shut itself off due to low battery.plugged phone so it wold charge. phone ever charged and it will not power on.
Это хороший вопрос?
Оценка 18
4 Комментариев
How much would it cost to get my charger port fixed in Chicago, Illinois?
из
My phone is not charging
из
I plugged my phone, but very second it keeps turning off and one saying power disconnected or power connected. I don't know whats wrong. I dropped it in the toilet but for 1 second and completely dried it off. I need help.
из
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Hi mi,
It seems to me that you need to replace your battery. Unfortunately, iFixit doesn't currently have a guide for that, but I bet that if you spend some time searching for a replacement battery you can fix it yourself.
Dante
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
so, how do you replace the battery? i see no where that you can open the phone.
из
Try holding the power button and the volume up or down button simultaneously for about 10 seconds or so. Should come on.
Оценка 0
Добавьте свой ответ
mi будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 4
За всё время: 3,125
