The Envizen V100M Tablet, is a tablet PC made by Envizen Digital, a brand under Diamondking Inc. This company makes several tablets, all of which run an Android operating system.
12вопросов Показать все
What should I do when the screen on my tablet freezes up?
When using an application, browsing through my photo library, or just normal use the screen on my tablet sometimes freezes up. I am not sure what to do when this happens as I usually just wait until the battery dies. Is there any other way I can fix this issue?
Это хороший вопрос?
Оценка 1
Добавить комментарий
4 Ответов
Does it allow you to turn it off?
Был ли этот ответ полезен?
Оценка 0
Hi Josh,
If you are able to turn off the device, you could then turn the tablet back on hopefully resolving the problem, if not you could try to reset the tablet to fix the problem. For a more detailed guide on how to find out the problem see the troubleshooting guide.
Hope this helps,
Nick
Оценка 0
I cannot put my PIN number in Everytime I try it do not see work I do not have one. So Everytime I put it in it say wrong PIN number so I cannot get in I need help or I'm going to return it
Оценка 0
1 Комментарий:
Can I get some help
из
Trying to reset tablet because I forgot pattern.Its now stuck on Fastboot. Won't turn off, or move to Recovery mode.
Оценка 0
Добавьте свой ответ
Josh B будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 4
За всё время: 672
