The 4Sight 9 is a low-end slate-form Android tablet released by 4Sight in March 2013. Identified by model number 4SPA0910C.
How do I perform a hard restart?
My tablet isn't working correctly and has trouble booting up, I was wondering how to wipe everything and restart it.
Это хороший вопрос?
Счет 4
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Trouble with Reset
If protection software does not correct the problem, on the back of the 4Sight there is a small hole that is labeled "Reset". Using a pen or a paperclip, insert the tool into the reset hole and you will fell a slight depress of the button inside. Pull the tool out of the reset hole and the device should be powering back on.
Trouble with Hard Reset
To proceed with a hard reset, there are several options for Android powered devices. Hold the "Up Volume" button on the side of the tablet, while holding the power button, this should start the reset process. If this does not work, you can try, holding the "Down Volume" button and the power button.
4Sight 9 Troubleshooting
Был ли этот ответ полезен?
Счет 1
thanks for the help
Счет 0
Добавьте свой ответ
Robert Shredow буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 17
За всё время: 1,749
