ipad 4 is not charging or turning on
hi, i have an apple ipad 4 wifi which is not turning on or charging, i have tried different charger but its still not working, even it is not recognized by itunes
Это хороший вопрос?
manubali811, besides different chargers you also want to try a different cable. If none of that works, consider changing the lightning connector. Use this guide for that.
Был ли этот ответ полезен?
hi, thanx for replying, can you tell me for what those 4 or 5 wires are there which are connected to bottom of logic board ner to home button flex??
actually while disconnecting them i accidently broked one pin(first from left side) and its track is gone so i can't solder it again
post an image of the damaged board and wiring with your question. Adding images to an existing question Lets see what you can do to fix it.
I can't believe the walk through has 27 steps! Just to open the screen. 😂
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 231
