The C720 is a low cost Acer ChromeOS based Chromebook. Released 2014 successor to the C710.
26вопросов Показать все
Вопрос закрыт
How do I take apart my mousepad to clean it?
My touchpad isn't clicking when I push on it. I think this is because there's grime lodged in the clicky bits. How do I take the mousepad apart so as to clean it and get it clicking like old times?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
There is no easy answer that I know of short of taking it apart. The bad thing about the trackpad is that there are a lot of components that cannot be separated and then put back together afterwards without special tools. I would take the c720 apart as much as you can until you can get a clear view of the underside of the trackpad (if it is held in by glue do not pry apart leave as is only remove screws and possibly tape if you are confident you can reseal the tape). Get some alcohol and clean it with a microfiber cloth both under and on top. Give it an hour to completely dry (overkill, but better to be safe) and then try clicking while it is still taken apart. If it is better but not perfect repeat until it is acceptable. Otherwise try searching around for a replacement which is most likely going to be the entire bezel and not just the trackpad itself.
Был ли этот ответ полезен?
Оценка 0
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 824
