Шестое поколение iPhone компании Apple, представленное 12 сентября 2012 года. Ремонт данного устройства схож с предыдущими моделями, требующий отвертки и инструменты для вскрытия. Доступен в версиях GSM или CDMA; с 16, 32 или 64 ГБ памяти; в Черном или Белом цвете.
2522вопросов Показать все
Can I take the screen out, without turning it off?
i can't turn of my iphone since the screen and touch doesn't work, so i opened it anyways, i took the screen out, but th phone is still ON, if i hit the Mute switch th phone vibrates indicating the vibra call mode ON, but the day after,it stopped doing it, so im little afraid, if i killed it by leaving it on without the screen, or the battery died, i bought the screen already might be here in 15ish days.
this is more a informative question that may help others in case they do such thing.
but if somebody knows about it would help me calm my nerves as well haha
thanks.
Это хороший вопрос?
Оценка 2
2 Комментариев
Once iPhone is open, just disconnect battery with plastic tool or finger nail.
из
the thing is, i already did it, and i just left the battery on. and the phone on as well. i hope it is OFF because the battery discharged, instead of a damage in the logic board
из
Добавить комментарий
5 Ответов
Выбранное решение
It worked OK, the phone can be left on without the screen, thanks for the help guys
Был ли этот ответ полезен?
Оценка 3
Yes you can but there is a risk of you hurting yourself (small electric shock) or a greater risk of the phone being damaged with contact of water since the phone is on. Just make sure that the exposed motherboard does not get into contact with anything so that no extra damage is done
Оценка 2
1 Комментарий:
the thing is, i already done it, the phone was ON cuz i could hear notifications coming, but i left the phone ON cuz i tough there would be no problem, but the day after it was OFF, i just wanna know if it is OFF because the battery discharged, OR the phone got damaged cuz i left it ON without the screen attached.
из
From my experience I want to say that it turned OFF because the battery discharged, this happened to me a couple of times, but after charging phone with either the lighting cable or a battery-case I noticed it still worked.
Now, the advice to you (if you ever do it again and you have no way to turn OFF the iphone) or to someone else who cannot turn OFF the iPhone 5 before opening it or changing the screen is that:
You do it REALLY careful, and you do the process of opening it the proper way (no more than 90degrees) then take out the little lid covered by the three(3) screws which covers the cables from the screen.
After you are done with this, then you should move to the battery connector on the lower part, take out the two(2) bottom screws, then disconnect the battery from the logic board.
Then you know that the phone is OFF, and don't forget to connect the battery and place all the lids with their proper screws after you are done working on it and before you close it.
For more help click on this Youtube video that I found informative with the answer.
https://www.youtube.com/watch?v=FBIxr8W7...
Оценка 0
I have simular problem. I dissamble phone cause wanted to replace camera, but forgot tu turn off the phone first -1gen SE. I separted screen form phone . Assambled everything back and now phone is not working. Doesnt want to turn on. Is it possible to damage your phone if you remove connections from inside the phone without turning it off first. I think there were 4 connections in my case.
Оценка 0
i was changing a screen and had this problem on an iphone 11, and was confused on what to do cause it was power looping and the screen that wasnt respontding to touch cause the screen was faulty so i went to a cool unhumid room and disconected the ribons and changed the front camera and speaker to a new screen then connected it and hoped for the best and it worked but was risky.
Оценка 0
1 Комментарий:
As long as you disconnect the battery before removing any other cables, it will be fine. Plugging and unplugging the LCD/OLED display when it's turned on is where we usually see problems with killing the display, so if the battery is unplugged that becomes a moot point.
из
Добавьте свой ответ
Joao Eduardo будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 11
За последние 7 дней: 43
За последние 30 дней: 228
За всё время: 25,090
