Kinect is a gaming peripheral for the Microsoft Xbox 360. It allows for audio and video input to let the player be the controller.
28вопросов Показать все
Why is my Kinect not tracking me when I play?
My Kinect device used to follow my body as I moved around the room. Recently, however, it stopped turning and following me. I can't manually move it either, it seems to be stuck. Is there a way to fix this?
Это хороший вопрос?
Оценка 1
Добавить комментарий
1 ответ
If your Kinect doesn't recognize your movements, try activating the 'Kinect On' setting found through the 'Menu', 'Settings', and 'Kinect' menus. You could also try adjusting the sensor angle or cleaning the camera lens. For more information, look at the troubleshooting guide.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Sean Gonzales будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 4
За последние 30 дней: 9
За всё время: 380
