will the screen from a G71 fit in a G72
I need to know if the two screens will interchange
Это хороший вопрос?
Это хороший вопрос?
You must match the resolution, backlight, and screen size to your current screen. You cannot deviate from your current screen specifications. A screen with different specifications will not work with your system.
In this case--you should be able to, yes, as both laptops use identical screens with the same 40-pin connector. Worst case scenario, you're looking at about a $70-$75 part.
Был ли этот ответ полезен?
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 3
За всё время: 168
