Released October 2008 / 2.4, 2.53, 2.66, 2.8 or 2.93 GHz Core 2 Duo Processor
376вопросов Показать все
Вопрос закрыт
Replaced DC-In Board but battery is still not Charging?
Hey guys,
Replaced my DC-In Board but im still getting NOT CHARGING on my system profiler. So does this mean I have to replace my battery? This question was in part with my other one that asked about the mojito spilling on the top left corner of the laptop.
So i ordered the DC In Board and replaced it. But still not charging. So is it safe to say that I need to buy a new battery?
Это хороший вопрос?
Оценка 0
Добавить комментарий
4 Ответов
Выбранное решение
This could be anywhere from the battery, or the cable connecting the battery to the logic board. Like remacberlin said you should first use coconut battery and see what it says. System profiler could also tell you how much amperage is left in the battery, a healthy batter is anywhere from 4200-5200.
Hope you figure it out.
Был ли этот ответ полезен?
Оценка 0
2 Комментариев:
okay. But I downloaded coconut battery and everytime i open it, it keeps crashing. Why is that?
из
I couldn't tell you exactly why this is happening. You could just look at your system profiler to see the health of your battery.
из
Наиболее полезный ответ
Have you tried coconut battery to check out the health of it?
Оценка 1
1 Комментарий:
I downloaded coconut battery but it keeps crashing. It says unexpected error. It keeps popping up when I open it.
из
I've also replaced DC-in and battery is still not charging... Coconut battery works fine and I also tried to replace the battery but no luck. Even though it happened because of liquid damage, there is no signs of corrosion nor burning on the logic board. Any idea how to fix it?
Оценка 0
You may need a new power brick
Оценка -1
5 Комментариев:
i used the the power brick on my friends computer and it works totally fine.
из
OH man, im totally a novice with this Mac stuff. Im so lost.
из
You have diagrams to show me what it looks like on here? That would so helpful. Thanks man.
из
you should buy a new power brick then or have apple swap it
из
The OP states the power brick worked on another computer.
из
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 1,203
