Replace fuel line that goes to fuel rail
2002 Honda Accord, how to replace fuel line
Это хороший вопрос?
Это хороший вопрос?
It depends on if the line is the high pressure side of the return line. If it's the return side cut the line clean and splice in a piece of high pressure fuel line that fits as snug as possible and double clamp it with hose clamps at each end. If its on the high pressure side you can get compression fittings at your local auto parts store and splice in a piece of plastic fuel line.
Был ли этот ответ полезен?
what size are the lines : feed, return, vapor . I found a kit that has all 5/16 size - not sure. And what about quick connects and flares . Brake lines were pretty straight forward , not sure with these .
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 15
За всё время: 5,114
2 Комментариев
What engine size? why do you need to replace it?
из oldturkey03
A pack rat has chewed a hole in it.
из Robert OFerrall
