The slim edition of the classic Xbox 360 with a 250GB HDD and built-in Wi-Fi. Repair requires intricate prying and special tools.
Вопрос закрыт
will not read game disk
My xbox 360 s was working just fine, but after changing game disks the system will not read any disk. Is there any way to clean the disk reader?
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Hi you can open the console and then the disk drive and clean the lens with q-tip and rubbing alcohol. That might help but you might need a new lens which are cheap. $5-$10. But without seeing it hard to say if it's the lens are something else. Also try cleaning the cache files might help with this issue.
Был ли этот ответ полезен?
Счет 0
1 Комментарий:
What do you mean by open the console? Remove the drive? Can I clean the lens just by opening the drive to insert a disk?
из
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 97
