First generation of Citroen's supermini car.
refill of C3 Aircondition system
How much R134a oil contains the aircondition system on an 2003 Citroen C3 1,4 HDI 16 Valve (92 hp) ?
Это хороший вопрос?
Счет -1
Добавить комментарий
1 ответ
Выбранное решение
This is the best info I could find. If you need to know the exact amount of oil there should be check your local library for a Chiltons manual for reference. I hope this is of some use to you. Ralph
http://reviews.ebay.co.uk/Citroen-C3-Air...
Был ли этот ответ полезен?
Счет 5
2 Комментариев:
Hi Ralph ,Thank you very much for your answer, after checking at my local library , I found out that the right amount of R134a was between 0,575kg and 0,625kg , the amount in the system was 0,320kg , and the air temperature in air-outlet was about 11 degrees celsius, after refilling to 0,600kg , it was about 4 to 5 degrees celsius , so quite a difference. Best regards Finn
из
Добавьте свой ответ
Finn буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 26
За всё время: 5,123
