A large smartphone by LG, released in fall 2014. The LG G3 (D855) boasts a Quad HD IPS display and a 13-megapixel camera.
180вопросов Показать все
Big bold vertical white lines after screen replacement
Hey I have a G3 and I recently replaced the screen with the entire frame.. After installing it worked fine. But after five minutes the screen started to show me a bunch of thick white line going from one end to another of the screen. Would you guys have any idea why this is happening ?
Это хороший вопрос?
Оценка 5
Добавить комментарий
1 ответ
Наиболее полезный ответ
Bad connection to the daughter board on the bottom of the assembly
Был ли этот ответ полезен?
Оценка 2
1 Комментарий:
I have the same problem after I dropped the phone, hopefully I just have to check the connections on mine. Thank you very much for this answer, you probably saved me from repurchasing the screen for nothing!
из
Добавьте свой ответ
blockboy21814 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 4
За всё время: 767
