iPod Classic 6th Generation. Model A1238 / 80, 120, or 160 GB hard drive / black or silver metal front
Fast forward stopped working
iPod Classic 160GB: The fast forward stopped working, is it a click wheel problem or logic board? There is no visible damage to the outside, it still seems to click down like it should. Rewind does still work, as well as menu, stop/play and middle button.
Это хороший вопрос?
Счет 1
Добавить комментарий
2 Ответов
Выбранное решение
Alan, it is possible that it is your click wheel, or the microswitch itself. You can use a multimeter to check the switches. The images should show you how to check. If the switch is not working, it will be difficult to obtain a replacement. You could A. try and get a used non-functioning logic board and harvest a switch from that or B. you can replace the logic board. Both choice would be considerably less expensive than a new iPod.
Был ли этот ответ полезен?
Счет 1
the button went out because of wear and tear. you can order another one to replace it or another ipod all together. they run about the same price.
Счет 0
1 Комментарий:
What broke exactly? it feels the same. Is it the inexpensive button or the expensive logic board?
из
Добавьте свой ответ
Alan буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 8
За последние 30 дней: 24
За всё время: 606
