Дата выхода 19 сентября 2014 года. Это маленькая версия iPhone 6 Plus с 4.7-дюймовым экраном.
Black screen, backlight problem?
I recently dropped my iphone 6 in the sink briefly. It was water damaged as the LCI shows red. I can still charge it; see it in iTune; and if I shine a flashlight on it, I can see the display, but the screen appears black without light.
Does it mean backlight fuse is burned? If so, I don't think I can do it without some real fine tools and micro scope. How much would it cost for the repair shop to fix it?
Thanks.
Это хороший вопрос?
Счет 12
1 Комментарий
Thanks for the answers. The reason why I suspect it being the backlight problem is that I can still see it clearly with a flashlight, and I can gesture and all the things. I thought if there's an LCD issue, I won't even see that.
из
Добавить комментарий
4 Ответов
Наиболее полезный ответ
Could just be the LCD. Clean the logic board and try another LCD
Был ли этот ответ полезен?
Счет 1
If the screen looks very dark but you can see the screen while using a flashlight or looking really closely its more than likely a backlight coil on the logic board so a new LCD/screen wouldn’t fix it. You’d have to take it to a repair shop that specializes in microsoldering and board level repair
Счет 1
I would try another screen. I would rule that out before venturing into the backlight repair. Also, look at the connector when you take it apart.
Счет 0
So I could be wrong . But it will be easier if you join fellow detailed pictures . If they are filters that will have a different color .
Счет 0
Добавьте свой ответ
Joe Zhao буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 10
За всё время: 28,675
