Guides and repair information for the second-generation of the North American Honda Odyssey, produced between 1999 and 2004.
42вопросов Показать все
My code for my 04 honda
I need a code for my radio Honda odyssey
Это хороший вопрос?
Оценка 4
7 Комментариев
You can get a honda odyssey radio code here; https://radiocodevault.com/honda
из
RIP OFF. Why should I have to pay for a code from my own radio?
из
Well, its better than the $70 the dealership charges... I used that radiocodevault.com site and it worked great :) It's like $15. No brainer.
из
did you read the answer by @oldturkey03 above
из
Показать 2 больше комментариев
Добавить комментарий
5 Ответов
Наиболее полезный ответ
I got a working radio code for my Honda from https://radiocodevault.com/honda/
Был ли этот ответ полезен?
Оценка 6
keisha, look on the side of the glove box or behind the ash tray for a sticker with a 5 digit code .If its not there then you will need to remove the radio to get the serial number and either call your Honda Dealer for a new number or post it back. You can also try this:
Turn your radio off.
Turn key to the ON position. Do not start, just leave ignition in ON position.
Press and hold the numbers 1 and 6 on your radio with one hand.
Using your other hand, turn the radio on while keeping 1 and 6 pressed.
Ten characters will appear on the screen, usually alphanumeric. Write down all the numbers you see.
Now you can either drive to the Honda dealer, provide proof of ownership, give them the numbers, and get your code. Or you might want to try this one online. https://radio-navicode.honda.com/
Оценка 3
there is usually a five digit number inside the glove box. when you turn the ignition on and radio read out says error code punch those numbers in using radio buttons this should reset system.
Оценка 1
12154 this is the 2004 Honda Odyssey code I have for my radio
Оценка 0
After you put the five digit code in is it supposed to reset on its own is it something I have to do
Оценка 0
Добавьте свой ответ
keisha будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 7
За последние 7 дней: 57
За последние 30 дней: 197
За всё время: 16,536
