Guides for the LTE version of the iPad Mini 2. Announced October 22nd and released November 12th, 2013. The iPad mini 2, originally known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
61вопросов Показать все
Improper color reproduction after digitizer replacement.
Hi all,
recently i broke my ipad screen digitizer, craking it. but there was no damage to screen (inner display working fine). I gave it for repair for digitizer replacement and also asked him to put tempered glass protector (this time being very cautious). after the replacement the screen lock function which switches off display and locks ipad if i close lid of my ipad case had stopped working. Nowadays the color reproduction is drastically different. Like the red lotus ios wallpaper which is of red shade is more of pink shade in my ipad.
im afraid i had been cheated to a duplicate screen. has my screen gone bad or something? pls help me out guys
Это хороший вопрос?
Оценка 1
Добавить комментарий
2 Ответов
Наиболее полезный ответ
the smart cover not working is likely due to the home button being replaced. A lot of the digitizers available that have the home button included don't support the smart cover function, which is unfortunate. The original home buttons can be used in repair but oftentimes does not make sense because the cost of the part with the home button installed is cheaper than the effort required to "dress" a digitizer with the IC and home button. Its also beyond the skill of some the low rent repair shops.
I'm curious about the change in the display. The display should not have been replaced unless it had been damaged in the course of the repair, if the display had not been replaced, you'd see no difference in the color sharpness and accuracy etc.
As for is the parts used likely "fake"? I can almost assure it. Apple does not sell parts for their iphones or ipads to anyone. There are parts that come out of the "back door" of the same factory that makes parts for Apple that are identical, there are parts that come out of factories that are not associated with apple in any way, and there are parts that are scavenged off of devices. If I had my choice of LCD, I'd choose the scavenged part but we can debate all day about where the "best" parts come from. So yes, if your LCD was replaced in the repair, its most likely a copy, sounds by your description to be not a very good copy.
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
Who cares about points I just want my iPad screen fixed can’t watch movies
из
The shop damaged your LCD during the repair and they replaced it with a cheap copy without telling you. And they used a cheap screen as well if your smartcover doesn't work. I would pursue a warranty return with them.
Оценка 1
Добавьте свой ответ
Sidhu150 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 11
За всё время: 1,227
