1.5 Core Solo, 1.66 or 1.83 Core Duo, or 1.83 or 2 GHz Core 2 Duo processor. This covers the first Intel-based Mac Mini models from Early 2006 to Mid 2007.
Dead Mac mini with no obvious damage
i received a mac mini with no signs of life.
there is no visual damage on the logicboard.
i removed the logic board and found some markings on the board.
testpoints at the following parts on the bottom side are marked "pink": U6400, U6410, U9500. those areas/parts are marked "blue": the circuits between R9537/C9522 and C9525/R9540, the printed text of L4732/R4732/R4733.
on the top side is only one "red" marking on C9521.
i've read a few things of other dying minis, some suffered the "failing fan issue" - but i don't think that those things are related. others died during the setup/update of 10.6.3.
the pram battery had 2.99v - but nothing changed after replacing it with a new battery.
and please - no "get a new mini" or "replace the logic board" answers.
i want to know if those computers are fixable or not - there are way to much minis out there that could do a great job in those times (mine is a 2ghz c2d with 2gb ram - not a "crappy" old 1.5 core solo)
the cpu isn't the problem, tired it with different ones, the brick works too - tested on another mini and it delivers around 18.5v to the board
any useful suggestions??
Это хороший вопрос?
Счет 4
2 Комментариев
+ This is the type of question you would answer. LOL
из
you're right. i think i would try to answer that
из
Добавить комментарий
3 Ответов
Выбранное решение
You could start by checking some of the fundamentals that the mini might not start without, like the Interconnect board, or something really straightforward like the power button. I have a mini that had been quite unstable until i took it to an apple store. I wrote down some numbers for parts, and took a few pictures before i sent it out and when i got it back it showed evidence that the logic board was removed but not changed. I am not aware of any way to test the logic boards, but your best bet would be to make sure that there are no types of obstructions to the interconnect board slot and no scratches/obstructions on the motherboard. you could try and run it "barebones" on a table laid out so that if some kind of case metal is shorting out, it won't do so. But other than that you would need some way of diagnosing the problem.
Был ли этот ответ полезен?
Счет 1
2 Комментариев:
the power button works, the zif cable lock for the audio board is missing - but i "replaced" it with something else. tried it barebone too (measuring insinde the housing wouldn't be the best idea ;-))
из
well, still no luck but i think it's time to close this. thanks fro helping
из
is clean inside? I have some experience with a 1 dead powerbook and 1 dead macbook pro, both with similar symptom and both pretty dirty inside...dirt stuck inside the fan's and vents...the overheat kill the graphic card. Some post on youtube recommend to bake or use a heating gun. I replace the mother board and both are working again. (before the surgery I didn't get any kind of
response when I push the power button).
Счет 0
I know this is a very old thread. I like the old mac minis. People are finding ways to add value or life to them even 3 or 4 years out of most support by hack loading 10.8 and adding SSDs and extra caddies. According to a thread on MacRumors the 2006 and 2007's mac mini boards had some issues with capacitors in the area around the power board. The 2007 had two or three that tended to go bad after a few years.
Here's the thread
http://forums.macrumors.com/threads/2006...
Счет 0
Добавьте свой ответ
markus weiher буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 7
За последние 30 дней: 28
За всё время: 10,815
