Руководства по ремонту и поддержка Leapster L-Max — портативной обучающей игровой системы для детей от 4 лет, разработанной и выпущенной компанией LeapFrog в 2005 году.
How do I get the battery to charge?
I cannot get the battery to recharge. The green light flashes while charging for more than 8 hrs. Battery still not charged. I have cleaned the terminals as recommended by the company, but no luck.
I am willing to buy a new battery if I could just find one.
Это хороший вопрос?
Счет 3
1 Комментарий
Mine has batteries in it but isn't charger not even turning on what do I do is there anyway to reset it?
из
Добавить комментарий
3 Ответов
Выбранное решение
i searched ebay a little bit and found a battery cover/holder.
i don't know whats normally in the leapster l-max - but this holder looks like a 4 x aa battery holder: CLICK
Был ли этот ответ полезен?
Счет 3
1 Комментарий:
Hi.
1. you can buy a wall charger (charge the battery connected to the wall socket) and connect to the ipod.
2. electro Shocks to your battery. You can use a power supply of 5V (for example an AC adapter with this power) and connect with a terminals to the pads of the battery this only has to be for a seconds, otherwise the battery will be burn.
after this process you can chek your battery with a multimeter
Счет 0
You plug in the charger to the wall, and then put it into your leapster device.
Счет 0
Добавьте свой ответ
Ruth буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 8
За последние 30 дней: 31
За все время: 6,478
