Released October 2008 / 2.4, 2.53, 2.66, 2.8 or 2.93 GHz Core 2 Duo Processor
376вопросов Показать все
Why is my screen freezing and flickering?
I'm having this problem since the beginning of May 2010.
Turning on my MBP (or turning it on from the sleep mode), my screen shows immediately many vertical, colored lines, then it starts to flicker till it freezes; I can see my desktop with many small dots, that slightly turn to white till I'm no more able to see anything else.
I realised that moving the panel and making a light pressure near the Esc / F1 digits, it seems working again.
In my opinion it can be some kind of contact between the lower and the upper part....but which one??
Inverter? Fluorescent Bulb?...?
Thanks in advance.
Это хороший вопрос?
Оценка 0
1 Комментарий
Could be the LVDS (Video signal) cable failing.
из
Добавить комментарий
1 ответ
Выбранное решение
This is not a real easy job because you'll have to rip apart the display assy and that involves ungluing the screen glass.
Guide to dimantle the computer here.
Video how to take off the glass here.
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
thx for the answer remac...is it easy to substitute it with a new one without going to the Assistance?
I'm using my MAc for work and it's no more under warranty.
из
Добавьте свой ответ
Luca Bocedi будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 3
За всё время: 3,608
