Battery Replacement Teardown Question
Is it possible to replace the battery on an iPod Touch 1G without removing the logic board from the body?
From the pictures it appears that there is enough room to get to the solder points while the logic board is still attached.
This would definitely speed up the repair and I just wanted to see what the purpose of removing the board is.
Это хороший вопрос?
Счет -1
1 Комментарий
I noticed you never got an answer to this. Are you still having this problem?
из
Добавить комментарий
3 Ответов
Выбранное решение
I would just follow the teardown to point myself. The iPod touches are relatively easy to break. The purpose of taking it out is probably so you have more space to work around and so you don't accidentally burn something
Был ли этот ответ полезен?
Счет 0
I'm fairly experienced with a soldering iron so the space shouldn't be that much of a concern. I still haven't done this project yet, the parts are in the mail, so if anyone else has some advice please let me know.
Счет 0
I've done it, although I kind of messed up the wire routing and didn't have enough slack to put in the battery, so I had to solder an extension, which then gave me too much wire and I had problems squeezing it all inside the case...sigh. Be careful about that.
So, yes it's possible.
The second one I did I just followed the directions. the board on the bottom isn't that hard to remove.
Счет 0
Добавьте свой ответ
Nathan Jones буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 14
За всё время: 1,219
