This is the first generation of Amazon Fire TV (model CL1130), released on April 2, 2014. It is a powerful media streaming and gaming device that allows the user to stream digital audio/video content to a high-definition television as well as play video games.
32вопросов Показать все
Why can’t I get internet access with a wired Ethernet cable?
When I try to connect to the internet using a wired Ethernet cable connection, the Amazon Fire TV will act as if there is no internet connection. What can I do to fix this problem?
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Выбранное решение
There could be a couple reasons for the Internet connectivity problems. Maybe the Ethernet cable is not correctly connected, or the router is not providing Internet access. Maybe it's also a hardware problem, in which the Ethernet input port may be damaged. For more information, visit
Amazon Fire TV Troubleshooting
Был ли этот ответ полезен?
Оценка 0
3 Комментариев:
useless information. how is this solved ?
из
I use the Amazon Cube 2nd Gen. When I connect ethernet Have to cut off Wi-Fi The problem that I have I cannot use my Amazon echo's Because when I cut off the Wi-Fi on Amazon cube It disable everything else So I have to use either or
из
Hasn't solved my problem must be problem with new fire stick
из
Why won't my internet is not working what is going I have xfined
Оценка 0
Добавьте свой ответ
cory burke будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 9
За последние 30 дней: 29
За всё время: 14,325
