i got same problem in my laptop .
it was also doesn't work with out battery>
but now its work perfect .
the solution is for my case maybe doesn't work for you guys im not sure
1-remove the battery and charger
2- press and hold the power button for around 30 sec
3- I tried to use different charger and plug it without battery
and its work perfect now without in sudden shutdown
so i guess we can summaries the solution by check the following :
1- the battery
2- the charger
3- driver (reinstall)
4-fan and cooling ( clean or change it)
5- check for any app or program that you install before the problem occur>...
good luck guys and i hope that will be helpful for allof you
regards
Был ли этот ответ полезен?
Проголосовали
Отменить
Оценка
0
20 Комментариев
its motherboard problem.u can call me or whatsapp me 00971569350246
из Ayaz Popular
I also have the same problem with my VAIO VGN-P530H. Please let's chat on Skype my ID is: alainbastien. Seems to happen since I updated the BIOS version REV to 3.5
из Alain Bastien
Seems Like motherboard Issue ..contact some repair man at near Your Place
из Jason
I dropped my sony vaios,but not that hard,when i try to turn it on,it only shows black screen then turn off emmidietly..please help me fix it.
из George Manzano
My sony vaio was shutting down after a few minutes, But after i reduced the refresh rate and resolution in the intel graphic settings the problem was fixed i hope that will help someone. Thanks
из Hicham Adel
Показать 15 больше комментариев
