Repair guides and support for LED, LCD, HD and other Vizio TVs.
Horizontal Line with Blurring Below
My Vizio 3D tv developed a horizontal line across the bottom third of the screen, and the screen below that blurs and clears every few seconds.
I've unplugged it, let it sit for a few days, factory reset it, and it's still doing it.
Это хороший вопрос?
Счет 4
9 Комментариев
What model is your Vizio?
из
It's a 50 inch M series razor LED.
из
I have the exact same issue. It was one line, now 2. Both visible at all times and switching from clear to blurry every 3-4 secs.
из
I bought a vizio 48" model D48N-EO and I have the same problem. The top half of my screen is blurry and there is a clear line where it changes. I have even made a warranty claim with Vizio and they replaced my TV yesterday. It worked for 30 minutes and even the brand new TV is doing the exact same thing. I am not sure what to do
из
Also, by any chance do you guys all have Direct TV as your provider? Just wondering if vizio doesn't work well with them. I have had my direct tv box replaced and hooked my box up to a different TV to make sure that wasn't the problem.
из
Показать ещё 4 комментариев
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Alec, horizontal lines are usually an indication of a bad LCD panel. check the tab bonding to the driver board and see if they are still properly placed and check for corrosion.
Был ли этот ответ полезен?
Счет 4
4 Комментариев:
I'm not sure I have the expertise to go about doing that. Any idea how much a fix of this nature, if this is in fact what is wrong with it, would be?
из
Tab bonding repair is very specialuzed and not a whole lot of places do it. It would probably cheaper to find a replacement from a different TV same model. I am sure you could check it. It is not as complicated as it sounds take the back off of your TV and post picture of it with your question. One image should be from the front with the line showing.
из
How do I do this
из
Pedro Molina Jr. sounds like a question but not sure what you want to do and what the problem is. Also, let us know what device you are looking for assistance with.
из
Actually there is a problem with LCD board,. Which is connected direct with LCD display.. Need professional technical person to repair the board..
Счет 0
1 Комментарий:
I have a 70 in that's doing the same and it's getting worse . About how much would it be to fix?? Ball park
из
Добавьте свой ответ
Alec буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 4
За последние 30 дней: 25
За всё время: 19,732
