The first generation Nvidia Shield Tablet released in July 2014. This device is often used for gaming, and has Wi-Fi and LTE capabilities.
24вопросов Показать все
How can I replace my sim card slot?
My tablet is reporting no sim even after i insert the simcard. I dropped it once and i suspect the sim port is broken. Can someone tell me where can i get replacement sim slot and the part number. Also a guide to fix should be helpful.
Thanks
Это хороший вопрос?
Оценка 3
Добавить комментарий
1 ответ
The original part appears to be ALPS SCGD1B0209 (http://www.alps.com/prod/info/E/HTML/Con...)
However, this part is not commonly available online.
This is the same part used in LG LK430 GPad F7.0, LG Optimus L5 E610, or LG Optimus L5 Dual E612. So replacement SIM card slots for these 3 devices should also fit the Nvidia Shield LTE.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
sankarasubramaniangiri будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 1,181
