The LG G4 was released in the US in early June 2015, as always focusing on high-end specifications and a refined fashion sense that makes it stand out in the premium smartphone market. Each version of the phone will have a different model number based on if it is sold by a carrier or unlocked (US or International). Some LG G4's are known to have bootloop problems.
Why is my LG G4 not charging properly?
I have connected my device to a power cord and it is charging very slowly or not at all.
What can I do to fix it?
Это хороший вопрос?
Счет 20
Добавить комментарий
10 Ответов
Выбранное решение
There is a series of steps you can take to attempt to fix this issue.
1) Press and hold the power key for 10 seconds to reboot the phone.
2) If that does not work, try using a different outlet or a different charging cable.
3) Next, you can try performing a hard reset on the phone. (Make sure to back up all your files as they may be lost in this process)
  • Turn the power off.
  • Press and hold the Power key and Volume Down key on the back of the phone.
  • Release the Power key when the LG logo is displayed, then press and hold the Power key again.
  • Release all keys when the factory hard reset screen is displayed.
  • Press the Power key to continue or any of the Volume keys to cancel this process.
  • Press the Power key one more time to confirm the reset.
For other issues related to charging the LG G4, please refer to this Troubleshooting Guide: LG G4 Troubleshooting
Был ли этот ответ полезен?
Счет 13
5 Комментариев:
Yes! This worked! Thank you.
из
Problem solve excellent i really appreciate that so much Thanks
из
I even tried this but nothing happened so I think there is a problem with the LG G4 charging port. Can you either recommend a place where I can fix it or can you recommend a way to fix it? It would help a lot
из
Hi my lg g4 hi15 is not connecting with pc in usb cable "use standard usb charger to charge in fast" only showed this plz help me
из
I have a LG Syylizt no cord I buy will stay in the port what to do?
из
I had the same issue with the LG Stylo 4; phone appeared to not be charging and would not power on. I remembered the trick of holding the power key on the right side and volume down on the left simultaneously, with charger plugged into phone. After about 20 seconds, it powered right up, showing a 100% charge. Performing the reset was not necessary, I allowed the phone to continue powering up once the LG logo appeared on screen. Once the power up completed, the phone ran as normal. Don’t perform the factory reset unless as a last resort.
Счет 4
5 Комментариев:
This actually worked. 20 seconds and also blowing into the charging port right after and connecting your charger.
из
My phone shows a question? Mark in the battery symbol. Help
из
i don't know what that means sorry i can't help
из
If it takes a "C" charger (which will plug into phone charger port either way) turn charging cord over and plug back in. This fixed my lg stylo 5
из
I almost panicked when my phone wouldn't power up after I plugged it in. The guidance in this posting worked perfectly and immediately--God bless Stacey!!
из
Hi I Have The Same Problem, Too... What You Can Do is Take the case and the case that came with your phone too, and you will see a white battery, now take that battery and leave it next to a fan for 15 minutes. Make Sure the fan has no dust in it and has maximum power. After 15 Minutes, Take The Battery and give it a little shake here and there. Put The Battery Back in, and turn your phone back on. Thanks! ;P
Счет 2
2 Комментариев:
This actually let me make it to the logo screen then went back off so I think my battery is just done thanks though
из
one thing you can do is buy a new battery there really cheap but you have to make sure it the right battery
из
hi i have the same problem it isn't anything wrong with it except the charging port.the charging port of you press the USB port in to hard it starts breaking.
note: it can easily be fixed by having a local company that fixes phones and tell them the problem.or you can fix it your self by getting a new port and taking the old one off and sadder it back in, that will screw somethings up if your not careful enough
Счет 2
Sometimes lint gets built up in the charging hole. Try removing it with a small object like a tack.
Счет 1
1 Комментарий:
A can of air works better and no chance of scraping or breaking then as well
из
When i put my lg g4 stylus in charge it indicate that it is charging in the usb mobe and it is charging very slowly i have also change my plug but it has not fix
Счет 1
I tried this and it didn't work my LG is dead and i cant charge it whenever I put my charger in while its plugged in with an outlet nothing happens and I cant seem to find how to open my phone to check the battery
Счет 1
3 Комментариев:
I have a android lg stylist no cord will stay in port. What can I do?
из
For those reading this in the future the Lg Stylo 4 & 5 do not have removable battery. if no response from screen try a soft reset holding power and volume down until phone starts to reboot. If that or a differant charger don't fix it you do have a 1 year warranty with LG . If past that and no insurance you are probably better off buying a new phone as yours probably has failed internally. Perhaps a new battery may help as well if you can find a shop to do reasonably.
из
That's the greatest fix comment ever
из
My LG 4 was DEAD. Batteries were fine, but it would NOT turn on no matter what I did (all the above suggestions). However, I found a YouTube video where the fellow said that when ALL else failed, stick the phone in the freezer for 30 minutes. Yes, bizarre. It worked. Phone started up immediately and has been working ever since. Hope this helps someone.
Счет 1
2 Комментариев:
You must be joking
из
It's true, same behavior with my G4, but after 3 times it didn't start anymore
из
Holy crap I put mine in the freezer for about an hour, lil more lil less, and did the soft reset and it totally worked!! My phone came on and is now currently charging . I hope it is completely fixed now. That would be fricken sweet.
Счет 1
1 Комментарий:
500 mb internal lol
This phone is fake. Yeah it has a big ass screen f
That is all it has, show and 500mb of internal that is no go .
My daily driver is a Galaxy s9 and I wanted to use the stylo to watch !!%@ when I came across it in a drug deal gone bad. I realized how mad when I was adding my normal start-up apps, then within minutes I got a freaking low storage space notification telling me to delete stuff! I hadnt even added my stuff.
Do yourself a favor and throw this crap against the closest wall. Then go get a real phone, minimam a refurb Galaxy s7 or up, you'll be all set....WITHOUT a bunch of annoying issues. 500mb internal lol
из
Solved:
  • I threw my lg stylo 4 $@$* against the wall I haven't had another problem with it again.
Счет 1
1 Комментарий:
lol!
Also try taking a hammer to it.
But for real - blowing out the phone port AND the cable ports with canned air is good. Don't forget - your cable probably drags on the floor or in the floorboard of your car, etc. It gets pretty filthy.
Also -
Also, for those who can remove the battery - take the battery out and using a SMALL WIRE brush - clean the metal connecting parts of the battery and also those parts on the phone. Just a brisk brushing until they look shiney again.
Meanwhile, I figure getting nearly four years use out of my phone is pretty good. I know the battery can't keep recharging forever but I will keep tryin' tips & tricks as long as possible.
Thanx for these other tips!
из
Добавьте свой ответ
carolinavind буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 11
За последние 30 дней: 63
За всё время: 146,365
