The second generation of the iPad with Wi-Fi, GSM and CDMA models. Some models were refreshed before the iPad 3. Repair is difficult and requires heat and prying. Released on March 11th, 2011. Model numbers: A1395, A1396, and A1397.
730вопросов Показать все
iPad 2nd generation not charging
How can I change or replace the battery?
Это хороший вопрос?
Оценка 1
1 Комментарий:
This question was migrated from http://meta.ifixit.com/Answers.
из
Добавить комментарий
2 Ответов
Are you sure its a battery issue? Does the device show its charging when you plug in a charger?
Был ли этот ответ полезен?
Оценка 0
The battery is behind the LCD. You would have to remove the glass screen, and then the LCD and you will see the battery. After removing both the glass and LCD its easy to access the battery. What will take time is the adhesive around the glass.
Оценка 0
Добавьте свой ответ
Elizabeth Dy Sun будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 428
