I can hear from speaker and earbud, but nothing from earpiece..
So, the problem is as I mentioned above, I simply can't hear anything from earpiece receiver, I can only make calls using earphones or the speaker phone.
Anybody have ideas about this?
Это хороший вопрос?
5 Комментариев
What exactly did you connect? I just received my iPhone from the store and the earpiece receiver is working badly. Any advice what cable to check?
из Deten
the 1st u should check is connection between earpiece with logicboard.. That's the part that make my earpice not workin...
из Otniel Yoreiza
I've disassemble the phone, removed the logic board and found the speaker connectors (those two small metal things). Should they be soldered to the board? Or are they connecting by touching the board? Maybe you have a picture?
из Deten
noo, don't solder it, they only need to connect properly to the board..., my problem happen because one of this pin is not touch the board....
из Otniel Yoreiza
Can you please specify what exactly did you do to the earpiece pins to make them touch the board?
I already found out that the earpiece works good but my problem is exactly the same as you had. I believe that my problem is in the left contact of the earpiece (left if you look on the disassembled iphone). So how should I bend it or what else did you do?
из Deten
