Why will my iPad Air not restore?
I have hooked the iPad Air up to my computer and it says I need to erase it and restore it. I have tried this and keep getting error codes. I called apple and they said I need to send it in and the repair will cost approximately $300. Is there a way I can fix it myself?
Это хороший вопрос?
2 Комментариев
Had the same issue, tried the solution about 8 times... with no sucess, and then.. it worked. Just saying because some people are saying it is not repairabel. After 3 days trying mine came back to live. So if you really need the iPad do keep trying, even if it doesn't work at first in my case it solved itself. I have to believe this has to do with batery problems
из Miguel Chambel
I’ve tried holding down the home button and power button many times and the connect to iTunes icon won’t show up at all
из cassandram313
