The LG G Vista features a 5.7″ IPS LCD capacitive touchscreen along with an 8 MP camera.
36вопросов Показать все
screen or digitizer black
Recently changed my digitizer because the original was badly cracked. I am unable to see anything now. I can hear the phone come on and it responds to touch but cannot see anything. Please help wit this issue
Это хороший вопрос?
Оценка 0
1 Комментарий
I have the exact same problem tho I didnt replace anything just woke up and screen is black I can hear its on I can type my knock pass code in and unlock it but unable to see anything all I really want to do is be able to pull pictures off of phone but says its in charge only mode when i hook it up to my pc. Is there anyhting I can do to change that?
из
Добавить комментарий
1 ответ
Выбранное решение
This is going to sound dumb but it happens more often than people will admit. when you installed the new didgitizer did it have a sticky film you put between the lcd and the digitizer? Did you peel the backing paper off it? Although it looks only slightly tinted it can stop the LCD from being seen .As dumb as this is it happens If not this there is the possibility you damaged the LCD when removing the old glass. Hope this helps
Был ли этот ответ полезен?
Оценка 3
Добавьте свой ответ
Dawn будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 2
За последние 30 дней: 3
За всё время: 239
