Nikon's D3200 DSLR has 24.2 megapixels. This model is geared towards casual photography enthusiasts with advanced specifications and performance.
66вопросов Показать все
Looking to build a remote video trigger
Hi!
I'm working to assemble a remote camera system, and am trying to figure out how to remotely trigger video using a wired connection on the Nikon D3200 (or similar) type camera. I see lots of traditional cable releases for stills, but I can't seem to find a pin out for the video trigger. I already have an array set up using GoPro's, so once I add the DSLRs it will be awesome!
thanks for the help!
Matt
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
ATG suggests if you are using Android, go to Google Play...
  • Type DSLR Dashboard /or QDSLR Dashboard
  • Pay and load that up to your Android
  • Buy an ATG's OTG Cable
  • Attach ATG' OTG Cable to Android
  • Use USB Cable that came with the camera, then connect to camera & Android
  • Turn on camera
  • On Android, look for DSLR Dashboard- touch it to open
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Matthew Kuhns будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 3
За всё время: 292
