Laptop manufactured by Asus, running on Google Chromebook OS. Released June of 2014.
Chromebook not powering on.
My Chromebook is not charging even when I plug it in, how can I charge it and turn it on?
Это хороший вопрос?
Оценка 1
Добавить комментарий
Ответов (2)
This will suck. Remove sd card. Power off. Hold volume - and power on. Conferm prompts. You should be in. The suck part is this hard start restors the device to stock. All is lost save what was saved to sd. All ways save every thing to sd card. This is less damaging to you in events as this. I hope this helps.
Был ли этот ответ полезен?
Оценка 0
If laptop refuses to power on when plugged into power source, your laptop may have a dead battery or the Central Processing Unit may need to be replaced. To address these problems, please refer to our troubleshooting page: Asus Chromebook C300M Troubleshooting.
Оценка 0
Добавьте свой ответ
Jake Van Loon будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 7
За последние 30 дней: 9
За всё время: 3,046
