The Lenovo A7 tablet is a 7-inch Android tablet released by Lenovo in April 2015. The A7-30 tablet was released in two versions, the 3G/Wi-Fi model (MediaTek MT8382M) version, and the Wi-Fi only (MediaTek MT8127) version.
33вопросов Показать все
Why has my screen gone wrong?
I turned my tablet on and all was working ok then all of a sudden the screen went like white/grey all over. It's not been knocked or dropped and is always protected in a case at all times. What has caused this to happen? It is only 3 months old.
Это хороший вопрос?
Оценка 0
1 Комментарий
You can't even remove the back on the device.
из
Добавить комментарий
1 ответ
Выбранное решение
Hi,
This is a problem with the Lenovo . You could try a hard reset to restore it to factory defaults - you will lose all your settings and data.
Here is a link to show you how.
Lenovo A7-40, A7-50 A3500 Factory Reset
If it doesn't work after that, given that it is only 3 months old, contact the manufacturer about a warranty repair or replacement.
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
The screen is absolutely blank so can't see or get to the settings.
из
Добавьте свой ответ
Nicole Smyth будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 4
За последние 30 дней: 5
За всё время: 222
