Руководства и информация по ремонту ноутбука Lenovo ThinkPad T430, 14-дюймового бизнес-ноутбука от компании Lenovo.
Power button LED Blinks when I press power button.
Lenovo T430. Tried following steps, No luck. Refer to my Video here.
  • Try charging the Battery to Full
  • Remove Battery and tried booting it with Power directly.
  • Changed the Keyboard.
  • Removed the Bios Battery and tried to switch on.
  • Removed the RAM and tried to switch On.
Это хороший вопрос?
Счет 2
6 Комментариев
Is there a pattern to the blinking?
из
No It just lits up and turns off. I dont think it is a pattern.
из
is there one or two sticks of ram
из
Do you get any fan sounds? Do you hear the hard drive spin up at all
из
yes i hear a fan sound, it comes and goes off (the sound)
из
Показать ещё 1 комментарий
Добавить комментарий
2 Ответов
Выбранное решение
Try removing one stick of ram if you have two and test one stick at a time in each of the two ram slots. Then test the second stick of ram in both ram slots this will tell you if you have bad ram or a bad ram slot. if it still doesn't work you need to consider getting out a multi meter and tearing open your computer and testing the circuit board starting at the power outlet and working into the board
Был ли этот ответ полезен?
Счет 3
2 Комментариев:
I tried the RAM swaps , no change. Also Fan wont turn on. I am not familiar with electronic circuits.
из
Even now 2021 i have that problem on my Lenovo All-in-One Computer IdeaCentre 300-23ISU (F0BY0041US) Intel Core i3 6th Gen 6100U (2.30 GHz) 8 GB DDR4 1 TB HDD 23" Touchscreen Windows 10 PRO 64-Bit
из
I have a T430 with the same issue. LEDs (power Fn F3 ) are blinks one but the laptop does not turn on.
I triedtoclean the connections, remove the batteries....no change.
Once i removed the RAM and the unit booted up.
So the issue is the following : it works with no RAM, but it does not work with installed RAM.
The problem is the same with the old and a brand new RAM also.
Any idea?
Счет 0
Добавьте свой ответ
ksenthilbeit буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 3
За последние 30 дней: 11
За всё время: 31,280
