The Inspiron 15-3521 has an optional touch screen feature and has a 15.6" display. This laptop is also complete with a matte finish and keyboard complete with number pad.
40вопросов Показать все
Why can't I install the usb driver?
After installing windows 10 there were a couple missing drivers. I troubleshooted the laptop in devices and printers and it fixed all the driver issues except for the USB2.0-CWR driver. It says it doesn't have it. I tried to update it from device manager but it says windows can't find the driver, go to the manufacturersame website. I couldn't find it on dell.com either. What should I do?
It says in properties that the drivers for this device are not installed. (Code 28)
Это хороший вопрос?
Оценка 0
3 Комментариев
have you updated windows 10 yet it could help
из
I'll try that thanx.
из
Ran a bunch of updates. Didn't change it. I had a problem on an hp pavilion recently where it didn't recognize the DVD drive. It seemed like a driver problem but was actually something in the registry that needed deleted and then it worked fine. Could this be something similar?
из
Добавить комментарий
4 Ответов
Выбранное решение
Hi,
Did you try this link, scroll to bottom and download Realtek USB 2.0 card reader?
http://www.driverscape.com/manufacturers.... If you have please ignore.
Был ли этот ответ полезен?
Оценка 2
1 Комментарий:
Thanks, Jayeff, your link worked great.
из
down load driver genius it should find the driver.
Оценка 0
Hey! It is easy! If you can't download drivers from official website, you can try to use a 3rd-party driver program to download driver for Windows 10. More detail: http://goo.gl/5h6ICN
Оценка 0
maybe you should look for the driver Sesua, try visiting http://www.aiydriver.com and find your laptop drivers
Оценка 0
Добавьте свой ответ
Jesse будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 3
За всё время: 1,496
