Компания Apple представила iPhone 5c 10 сентября 2013 года. Ремонт данного устройства схож с предыдущими моделями, требующий отвертки и инструменты для вскрытия. Доступен в версиях GSM или CDMA; с 8, 16 или 32 ГБ памяти; в цветах: Белый, Розовый, Жёлтый, Синий и Зелёный.
Home button will not work after replacement
Hello,
I have this stubborn iPhone 5c which I can not get the home button to function. I have replaced both the button and the charging port twice to no avail. Even ios restore. Does anyone have knowledge of this issue?
Это хороший вопрос?
Счет 1
2 Комментариев:
did the home button just stopped working by itself? or did this occur after a repair?
из
I was given this phone by a customer. He claims it was never fixed before, I don't see any signs of previous tampering it is just "the home button would only sometimes work."
Well in my experience with it thus far it has never worked.
из
Добавить комментарий
2 Ответов
check the contacts on the charge port and make sure they are not bent or damaged, also make sure the contacts on your button piece are aligned correctly as well. One issue during a charge port installation can be the port not being aligned properly as well. If all pieces are in correctly and the issue persists it could be a board or software issue. I would try a settings reset as well if all pieces are in there correctly.
Был ли этот ответ полезен?
Счет 0
1 Комментарий:
Hello,
Thanks for the reply, but I wonder if you read the post and not just the title. I have replaced a thousand charging ports, and this one in particular I have done twice, as well as the home button. I even did the full restore already. I am often able to test a home button on a charging port by simply holding the contacts together, as the screws do absolutely nothing for its function. On this one, however; I can not get function even with the home button and charging port fully installed.
из
The cable with the home button contacts must be aligned exactly right. The cable has two alignment holes that fit over corresponding little nibs when the cable is bent over itself i the proper way. There is also a bit of adhesive on the back of this cable to keep it in place. Then the whole assembly is screwed down. If the contacts are not bent then my guess is that the cable with the contacts is not indexed properly. Regards,
Ed
Счет 0
Добавьте свой ответ
AWT буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 14
За всё время: 139
