Samsung Galaxy S6 Edge+ — это увеличенная версия смартфона Galaxy S6 Edge. Проблемы с зарядкой
Front Glass Replacement for Galaxy S6 Edge+ Plus?
I have been looking for a replacement screen for the past 2 months. (Screen broke 1 month after buying the phone.. WITH A CASE ON IT!) It still works but Its a big eyesore.
Это хороший вопрос?
Счет 5
Добавить комментарий
10 Ответов
Выбранное решение
If the glass gets damaged, the easier and safer solution is to replace the complete screen assembly since the glass, digitizer and LCD screen are bonded together tightly by the help of very strong adhesive, and it is very hard to separate neither of them for individuals. Though there is front glass replacement sold separately. The reason is that it is possible to remove the glass from the LCD, as long as you have special tools as well as professional skill. Otherwise, it is better to replace the whole assembly rather than just the glass. Here is the s6 edge+ screen replacement from the third party: http://www.witrigs.com/oem-lcd-with-digi...
Был ли этот ответ полезен?
Счет 2
I wonder how much Samsung charges for a screen replacement because it is definitely cheaper than anywhere else for S6 edge and higher in Australia.
Счет 2
I can help you it it's easy as 1 2 3 add me on Facebook jp Joseph
Счет 2
I agree with kristastic1990 ... however it might be cheaper to buy a second hand S6 edge on eBay and then sell your broken glass s6 edge back on eBay ... difference might only be $100 - $150 as people with the right machines will buy it to refurbish the glass only.
Please do not attempt to a glass only replacement. I have been a tech for 5 years with mobile devices and its just not a feasible repair.
Счет 1
You'd better replace the whole AMOLED display, only replace the glass is very difficult and need some equipment. Here is about how to replace Samsung Galaxy S6 Edge + display. Разборка Samsung Galaxy S6 Edge Plus
Счет 1
1 Комментарий:
jpride56j5 how can I get intouch with you ? I've got a s6 edge plus that needs a new screen ? Thanks
из
I don't know how you have searched for replacement screen. My first suggestion for you is to replace the screen at Samsung store. It might cost a lot, but reliable. You can also just find a common repair store, which should be cheaper. Or, you can buy a replacement screen online and install it yourself. Alibaba should have the cheapest screen. But, sharpen your eyes.
Счет 0
1 Комментарий:
See for yourself! Repair stores refuse to even try to fix it! I wouldnt ask here if I didnt look before.
из
My Brother in Law says the 6 edge plus can't be taken apart, can I get the answer on this ? Yes we're fusing over it lol .
Счет 0
1 Комментарий:
It can, but isn't the easiest of phones for disassembly, quite a bit of adhesive is used to hold the front and back in, and to service a lot of the stuff, the screen needs to be removed.
из
samsung s6 edge front glass change
Счет 0
Yes
I want to replace samsung. S6 edge. Plus screen. Display
What. Will I do
Счет 0
Samsung 6 edge plus replace screen
Счет 0
Добавьте свой ответ
REYESRZA буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 4
За последние 30 дней: 19
За всё время: 27,606
