The HP Pavilion dv3, released April 2009, is part of HP's dv series. The dv3 may have various options for specific components, but comes standard with a 13.3 inch screen and weighs 5.5 pounds. The dv3 is easy to disassemble, due to its simplistic internal layout, and will most likely just require a screwdriver or two.
Why is it not in english language
Laptop is not in English
Это хороший вопрос?
Счет 0
1 Комментарий
Whats the operating system?
из
Добавить комментарий
1 ответ
Выбранное решение
Get into the settings or control panel depending on which version of windows you have .Go to time and language and select language of choice . To help find what you need use google translate to help navigate the language its presently using. Hope this helps
Был ли этот ответ полезен?
Счет 2
Добавьте свой ответ
janetgildein69 буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 9
За всё время: 130
