Weird keyb.oard issue with my Alienware M14X
I am experiencing the strangest of prob.lems with my MX14 keypadb. So as you might have already realized, there are full stops at the wrong placeb. This is what happens when i press the b. b.utton and the fullstopb. b.utton
When i press the B b.utton the letter b. is followed b.y a full stop and when i press the period key it is followed b.y a b.
This silly thing is tearing my head, any help would b.e appreciated
Это хороший вопрос?
Hi Jayeff,
Thank you so much for taking time out to helpb. I tried it b.ut it didnt work b.ecause filter option was already turned offb. Thank you very much thoughb.
из Yatish Suvarna
Hi,
Can you plug in a USB keyboard and see if you have the same problem when you use it?
из jayeff
Hi,
Check to see if you have the Turn on Filter Keys enabled.
Go to Start > Control Panel > Ease of Access > Change How your Keyboard Works > Un checkTurn on filter Keys
=== Update (12/26/2015) ===
Hi,
The info in this link may be of some relevance.
http://www.ofzenandcomputing.com/turn-of...
из jayeff
Hi Jayeff,
Thank you for the response b.ut that didn't work
из Yatish Suvarna
