Компания Apple представила iPhone 5s 10 сентября 2013 года. Ремонт данного устройства схож с предыдущими моделями, требующий отвертки и инструменты для вскрытия. Доступен в версиях GSM или CDMA; с 16, 32 или 64 ГБ памяти; в цветах: Серебристый, Золотой и «Серый космос».
3530вопросов Показать все
Вопрос закрыт
iPhone 5s lines when only LCD connected
Hello,
I just replaced a iphone 5s screen, but now there are vertical lines on the screen. I tried other lcd's and there are giving me the same problem.
Why are there vertical lines when only the LCD cable is connected? FPC connecter of the LCD?
Это хороший вопрос?
Оценка 0
Добавить комментарий
4 Ответов
Выбранное решение
I fixed my problem now: On my case there were 2 problems:
1. Damaged touchscreen connector
2. Lose contact in the ribbon flex of the lcd itself.
Был ли этот ответ полезен?
Оценка 0
probably the fpc connector on your motherboard
check for damaged/bend pin or dust
and clean the conector maybe there is some dirt/oil
Оценка 0
1 Комментарий:
Did that already, I connect ONLY my LCD flex to the motherboard. It still giving lines, There is no visible damage on LCD fpc, but there is damage on Digitizer fpc.
So the question? is it FPC digitizer, or FPC lcd?
из
in this case if the FPC on your mother board are fine
all you need is to order a new LCD assembly
it will surely cost more to repair the fpc on a lcd assembly than buy a new one
Оценка 0
1 Комментарий:
But I already tried like 3 new LCD assemblies. Which are giving the same problem.
из
I'd also like to know the answer to this. There is no visible damage to the FPC Connectors on mine... They have been thoroughly cleaned with alcohol and good working screens tested.
Update (02/05/2016)
It's the u3 display ic.
Оценка 0
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 142
