No bootable device found
This is the second time this problem has occurred, the first time iit happened i changed the harddrive but the problem has appeared again!
Это хороший вопрос?
Это хороший вопрос?
I would consider also changing the hard drive cable with the drive: Замена жесткого диска HP G72
What is happening to the drives and do they work in an external enclosure or universal adapter?
Был ли этот ответ полезен?
Its being detected as an external but u cant see any files in it... Can only see 2partions
За последние 24 часов: 1
За последние 7 дней: 7
За последние 30 дней: 11
За все время: 382
4 Комментариев
Hi,What is the model number of your HP?
из jayeff Поделиться
Its hp g72.....
из Murtaza Kadibhai Поделиться
In bios harddrive is not detected.... I tried another its working fine.....
Hi,
The question to ask yourself is , why are the HDDs failing so soon, especially if the 2nd one was new.
