Fat PS3 YLOD Repair Have tried repair twice still no fix.
After the first fix I came to the possible understanding that I may have not been thorough enough with the repair so I chose to do it again. With more determination and better attention to detail was more thorough but again the repair did not work. At this point what can I do, anything?
Это хороший вопрос?
2 Комментариев
Are you applying new thermal grease? What's happening when you try to turn it in? Which guide are you following?
из iMedic
Yes I used new thermal paste. I followed multiple videos on YouTube that have used all the same techniques. Reflow the solder correctly, apply new thermal paste, reassemble. Once turned on the fan is low and idle for about 5-10 seconds and then full speed and then proceeds to shut off with the flashing light.
из Daniel Ames
