2009 Ford Escape - Wont shift out of park
My Escape started to stick in park recently . You can pull on the shifter lever till your blue in the face and it will not budge and another time it works fine and shifts smooth like there was nothing wrong . When it wont shift if I leave it for a while and come back to it it will usually work . Can anyone suggest a fix for this
Это хороший вопрос?
7 Комментариев
My kid shoved a penny down where my gear shift is will that affect my car?
из Ron C
i've got an 08, same issue... but... i'm married to a master ford mechanic and i can tell you it's not the break switch or selunoid etc on mine, i even have brake lights (first thing he tried was the switch). he's ripped it apart trying to find the the cause, which from a brief read on the net is rather common with the escapes.
из ceyllynn
Brake switch on mine. Easy to replace cost $51. 00
из Ckarat
After replacing the bpp switch my car won't start or nothing now what. But will shift out of gear
из alycia.gregory
Had the same problem on my 05 Escape shifter won't come out of park no brake lights change the brake light switch still won't come out of park still no brake lights where do I look for the problem next
из chuck.northern
Показать 2 больше комментариев
