The Bose 3-2-1 Home Entertainment System is a series of DVD-based home media systems in the Bose 2.1 home theater line. The Bose 3-2-1 Home Entertainment System was sold between 2001 and 2006 and was available in black and graphite colors.
91вопросов Показать все
No sound output from Bose 3-2-1 Base AccustiMass Module.
My 3-2-1 Bose AccustiMass Base Module no longer emits any sound. The LH and RH speakers operate properly. Input selections AUX, CD/DVD, VIDEO 1 and VIDEO 2 are also OK?
How can I troubleshoot and repair. Also, a schematic and parts list of the module circuit board would help.
Это хороший вопрос?
Оценка 4
4 Комментариев:
Need two screws one broken to go in to back of media centre for 321 Bose series 0330 19350100158AS . The small screws that the lead plugs in to.
из
Ps321 no sound but its light up green . What should I do I tried the unplug plug in dint work. looked at fuse it’s good. Help
из
My RH speaker is no sound output
из
My home theatre bass are damage
из
Добавить комментарий
2 Ответов
Hi,
Have you tried the following two reset options:
Turn the media center off for 10 seconds, then on again, to restore communication between the media center and the speakers.
Unplug the Acoustimass module power cord from the outlet for a minute, then reconnect it. This allows the unit to reset itself.
Был ли этот ответ полезен?
Оценка 0
2 Комментариев:
Jayeff, thanks for your quick reply. I already tried the (2) options suggested prior to submitting my inquiry. There was no change or improvement. The base AcoustiMass module still doesn't provide any output whatsoever. Any other suggestions.
из
Which w should read what
из
have you checked if the tranformer in the base module have a voltage output
seems like a common problem
Оценка 0
Добавьте свой ответ
Louis Repassy будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 24
За последние 30 дней: 66
За всё время: 15,333
