Where is temperature sensor located?
Where can I find the temperature sensor on my 2003 Mazda Tribute 4 cylinder engine
Это хороший вопрос?
Это хороший вопрос?
@chasp you did not tell us exactly what temperature sensor you are looking for. It might also help if you tell us why. The CTS (coolant temperature sensor) is screwed into the thermostat housing near the top radiator hose.
Был ли этот ответ полезен?
Yes it's the coolant temperature sensor
under the intake manifold on the back of the alternator, better to remove the alternator so u can see the coolant temprature sensor.✌
За последние 24 час(ов): 6
За последние 7 дней: 16
За последние 30 дней: 88
За всё время: 8,420
3 Комментариев
Where is the heat sensor located on Mazda tribute 2003-2007?
из Lavianna Stoops
where is the location of thermostat switch sensor of mazda tribute 2001 and to remove
из Ferdinand Quijon
Where is the heat sensor located?
из Lavianna Stoops
