Where is temperature sensor located?
Where can I find the temperature sensor on my 2003 Mazda Tribute 4 cylinder engine
Это хороший вопрос?
Это хороший вопрос?
@chasp you did not tell us exactly what temperature sensor you are looking for. It might also help if you tell us why. The 2003 Mazda Tribute with the 2.0L 4-cylinder does not use a traditional Engine Coolant Temperature (ECT) sensor that sits submerged in antifreeze. It uses a Cylinder Head Temperature (CHT) sensor that measures the temperature of the metal itself, and the computer uses that reading to calculate the coolant temperature.
Был ли этот ответ полезен?
Yes it's the coolant temperature sensor
under the intake manifold on the back of the alternator, better to remove the alternator so u can see the coolant temprature sensor.✌
За последние 24 часов: 0
За последние 7 дней: 5
За последние 30 дней: 41
За все время: 9,943
4 Комментариев
Where is the heat sensor located on Mazda tribute 2003-2007?
из Lavianna Stoops
where is the location of thermostat switch sensor of mazda tribute 2001 and to remove
из Ferdinand Quijon
Where is the heat sensor located?
из Lavianna Stoops
Any video available?
из SOLOMON POKU-ASARE
