Ipad 3 Processor Chip Overheating
Hello,
I really do have an issue here. I have an ipad 3rd gen with 3g built in but I go to use the ipad and it will be very hot in the bottom left corner after a couple minutes which eventually left the ipad to not boot up and had to restore overtime. The restore fixes it but again the ipad gets hot so I ended up investigating more why it was becoming so hot.
I took the ipad apart and sourced out where the heat is coming from, and removed one of the shield plates giving access to the processor A5X chip.
After a couple minutes of gameplay, the chip is very hot and you cannot touch it. This seems to be the only place where its getting really hot. I did notice there was a thermal pad on it which had bubbles on it and so did the chip so I am not sure if its water damage or what but I really want to know what I can do to fix it because it obviously isn't normal to behave like that.
Any help would be appreciated.
  • Also the ipad will start to freeze up when it gets super hot and apps sometimes will crash and won't open again even after restarting.
Это хороший вопрос?
Счет 0
4 Комментариев:
Can u charge stone dead iPad, when battery reach 0% can u wake it up with charger?
из Поделиться
yes it will turn back on after charging but then it will boot loop causing me to restore again.
из Поделиться
then sorry my friend I dont know what is. :(
из Поделиться
it sounds to me it's a faulty A5X chip or water damaged but I really am unsure..
из Поделиться
Добавить комментарий
